And if you have the QCW then this all changes again because your
spoilboard surface is now considerably higher than without it.
There is no one ‘best’ height. If there was you’d only have a choice
of one set of holes, so basically no choice.
You choice of dust boot will complicate your decision. Since the dust
boot needs to slide out of the support arms toward the front, the dust
boot hose connection may not clear the underside of the Z-Slider. At
least that’s the case for me with the Suck-It Pro
However, if the channel in the support arms were open in the back as
shown below, you could slide the dust boot out toward the rear and there
would be no interference with the Z-Slider. At least that’s how it’s working
for me since I modified my arms a couple days ago.
