MattD1079
(Matt D)
January 12, 2025, 10:52pm
1
My z20 slider thinks it has traveled farther than it actually has. It moves about 65mm and shows to move 160mm. It was working fine one minute then starting acting up. I reflashed the microSD and when that didn’t work I bought a new microSD and tried that. Nothing helped. Any ideas?
Is this a new z20 install?
I read somewhere that the z20 needs new software.
MattD1079
(Matt D)
January 13, 2025, 2:52pm
3
No, this is existing. Been running this setup for a few years now
robcnc
(Robert)
January 13, 2025, 4:03pm
4
DId you reset configuration as well?
Occasionally, there may be a time when you need to reset the machine back to factory defaults. Here’s how to perform a configuration reset. (machine not working correctly, machine cutting shrunk or stretched, ipp rail upgrade sizes)
Please note, resetting the configuration will change any custom values you have entered (i.e. probe size, stall homing settings). Please make note of these BEFORE resetting so you can input them back in once reset.
Always ensure you’re on the latest firmware (as …
MattD1079
(Matt D)
January 13, 2025, 5:49pm
5
Yes I did do a reset of the config after reflashing the OS
