Z-20 upgrade issues/error
I finally got around to installing the Z-20 slider upgrade on my Journeyman and am encountering some errors that I cannot solve.
The physical install went fine and it worked before I changing the settings as per the installation manual. I also upgraded to the latest firmware 1.3 prior to this and then changed the settings. I cannot figure out what is going on and I even tried to change the settings back but I am receving the following error:
Non-rapid move with zero feed rate
While executing GCode block:G91 G1 Z[#<_z zero_backoff>] F[#< _z_search_velocity>]
At: :2
Caused by: -rapid move with zero feed rate
Anyone run into the same issue? Any suggestions so I can get this back up and running?
Reset the configuration and then restart
Thank you, I have tried that a number of times. Can you be more specific so I can ensure that I am not missing anything. What steps should I take? Anything else that I can check?
Hey Makermatt,
this is an error in your g-code. You cannot execute G1 (Linear Move) with F (Set Feed Rate) unset. Use F first to set it to a non-zero value.
I am receiving the same error. How did you fix it. please be specific.Thanks
I had to reset the configuration and restart. There is a button that allows you to do this. Once I did that it has worked great
Thanks Matt , where is the button?
