Air cooled spindle?
Hey Greg,
[quote=“CommunityUser5, post:17, topic:12251”]
Note that if you bought a cheap chinese kit, usually it comes with a so-called “aviation connector” and it is expected that you make the spindle cable yourself. I strongly advise against trying this. These connectors are not made for the use in power applications, and the problem with them is that their strain relief clamp usually will not allow cables of more than 7.8 mm wire diameter, which limits these “aviation connectors” to cables that are underdimensioned for the spindle’s current. The LAPP Ölflex spindle cable shown above (LAPP #0026251 for 1.5 kW spindle) is 9.9 mm in diameter and the LAPP #0026271 for 2.2 kW spindle is 11.8 mm in diameter (nearly half an inch), so no chance to get such a cable into such an “aviation connector”.
Therefore for these cheap chinese spindle kits, I strongly recommend NOT to try to make your spindle cable yourself, especially because on top of it all, the connector is not made for crimping the wires onto it, but it is a connector to be soldered. Since the connector and the cable both have a high mass, a soldering gun for electronics will not be enough, you will at least need a 80 W soldering gun with temperature sensor.
Further information for DIY
See also
