Buildbotics controller, updated firmware, flashed Pi drive - no WiFi
Hi guys, poured through the threads, and done all the things and still can’t connect to the controller over WiFi.
I’ve had this machine since ‘21 and have had zero issues until yesterday.
Updated firmware, gut a repeater in the shop, flashed the Pi card, and I see ‘connected’ to my WiFi, but no IP address.
What am I missing? Totally frustrated
Hi
If your message says you are connected to WiFi and no ip address check to see if your router requires you to add a reservation for the MAC address (Hardware address). If you assign an ip address in DHCP to the MAC address then it will get the IP address you chose. If you can type a dos command of ipconfig it will return an ip address. If this starts with 169 then it is not talking to any other device on you network. I.e the ip address will be 169.x.xx format if it it an IP v4 address. Hope this helps
Thanks for the insight and help. I reset the configuration (could have sworn I did that after all the things) and I’m back in business.
Preciate y’all!!
Andy
