Can someone measure their Elite Foreman Feet for me?
Hey litany,
the Foreman’s width on the feet is identical to Journeyman’s. The Foreman’s depth is 16" more than Journeyman’s. Journeyman’s depth is identical to Wooworker depth. Footprints of Original/PRO Series machines are identical to Elite Series machines. The difference in space you need is in length of different stepper motors protruding the feet, and the depth of drag chains (see “Space to reserve around the machine” below), but there is no difference at the feet’s bases.
Here is a quoting of a post with Journeyman dimensions. Subtract 16" of width to get Woodworker footprint, add 16" to depth the get Foreman footprint.
See also:
It contains a diagram of the Foreman QCW frame:
The Foreman’s Y feet are taller as on Journeyman and Woodworker, as it has 50 mm rails instead of 35 mm rails on the Y axes. Journeyman and Woodworker have 35 mm rails on Y axes. See here for an image of the difference between 35 mm and 50 mm axes.
