@Brandon - when you are just starting out, I recommend less expensive bits from E-Bay. They might not be perfect, but I’ve been using them for 6+ years (same bits) without any problems. I do have some of the more expensive bits, and with my conservative speeds, I don’t see any difference in performance. With the OF, I do plan on pushing the machine more, so maybe things will change. But in the end, I just want reasonable milling times and repeatability - I don’t need full depth cuts at 200ipm when 50% DOC at 60ipm works.
@RonHoppus - I have some of their V-cutters. They are “OK”. I got a combination of the super inexpensive ones and the “regular” priced ones. Let’s just say you get what you pay for. The regular ones do fine, but I did break the tip off just about all of my bits at some point - no clue when it happened. They still cut, but the finer details are lacking. It is time for me to upgrade my V-Cutting arsenal.
I have also purchased from https://www.the-carbide-end-mill-store.com before. The have a wide assortments of bits at reasonable prices. Good ‘middle of the road’ prices and bits.
Here’s a list from my bits video:
Budget Bits ($):
Small Diameter Bit Set - http://ebay.us/mEIb0O
1/32", 2 Flute, Up Cut End Mills - http://ebay.us/JRtiqw
1/16", 2 Flute, Up Cut End Mills - http://ebay.us/P47Jl1
1/8", 2 Flute, Up Cut End Mills - http://ebay.us/KwKIKi
1/8", 2 Flute, Down Cut End Mills - http://ebay.us/Pb0Sq3
1/8", 1 Flute Up Cut End Mill2 - http://ebay.us/XgHC2G
1/4", 2 Flute, Up Cut End Mill - http://ebay.us/efGr3b
1/4", 2 Flute, Down Cut End Mill - http://ebay.us/P3aPfy
Higher End Bits ($$$):
1/4", 2 Flute, Up Cut End Mill - https://www.toolstoday.com/v-13780-46315-k.html
1/4", 2 Flute, Down Cut End Mill - https://www.toolstoday.com/v-13781-46415-k.html
1/4", 1 Flute, Up Cut End Mill - https://www.toolstoday.com/v-13351-51404-k.html
1/4", 1 Flute, Down Cut End Mill - https://www.toolstoday.com/v-13979-51504-k.html
1/8", 1 Flute Up Cut End Mill - https://www.toolstoday.com/v-13375-51410-k.html
1/8", 1 Flute Down Cut End Mill - https://www.toolstoday.com/v-13977-51510-k.html
1/8", 2 Flute, Up Cut End Mill - https://www.toolstoday.com/v-14140-46127-k.html
1/8", 2 Flute, Down Cut End Mill - https://www.toolstoday.com/v-14107-46227-k.html
60 Degree V-Bit - https://www.toolstoday.com/v-5705-45705.html
90 Degree V-Bit - https://www.toolstoday.com/v-5704-45704.html
