Woodworker X35, firmware is up to date. Just moved my Onefinity and after setup my X axis cut to Y axis cut is nearly 1: 1.45, so if I’m cutting a 4" square it works out to 4" tall, 7" long. I have swapped back and forth between Imperial and Metric, reset the unit several times, tried multiple files, and cleaned the ball screw. Basically if I cut a square sign it looks like someone grabbed it on either side and ‘stretched’ it.
