UPDATE: With the release of 1.0.9 firmware, these settings are now part of the default configuartion.
Ensure you are on 1.0.9 firmware (https://forum.onefinitycnc.com/t/firmware-update-1-0-9-12-17-21-latest-release/84830) or later and then reset the configuration, choosing your correct machine configuration: How To Reset The Configuration To Defaults
(OLD)
These settings only apply to X-50 Woodworker and Journeyman with the 1616 ballscrew configuration.
Please note: these settings are in MM.
To change the Travel Per Rev:
To Change the soft limits (distance the rail can move):
**The max soft limit for the woodworker is: 816mm or 32.126 inches **
**The max soft limit for the journeyman is: 1220mm or 48.0315 **
please note: machines with a 1610 ballscrew must set the travel-per-rev to 10mm.
