Has anyone tried buiding a Sharpie holder for your Makita router collet?
I have a mockup built that looked like it might work to mark up my spoilboard to simulate
the exact tool path, but I ran into a problem with the Z height error. Granted this Sharpie holder is much longer that a router bit, but I can fit it into the collet with a bit of room to spare against the spoilboard.
I will attempt to type the error, which by the way locks up my machine and requires a full restart and homing to get started again.
Z axis position 25.3 mm is greater than maximum soft limit 0 mm While executing GCode block GO Z1.5 At; 1 uplad1 Pocket 1.ngc:6
Is there a setup I need to make to allow for the maximum Z height?
I use a “.22 cal rifle laser” inserted in the collet. That negates the need to worry about z height changes by making sure it is zeroed well above the work piece. Just a thought.
@Rkeen221 , isn’t the error stopping the machine from moving into a position is physically can’t reach? If you somehow bypass the error, won’t the machine crash?
Perhaps your solution is to get a shorter marker. You can buy stubby sharpie’s that don’t stick out of the collet so much.
I also often need to mark the spoilboard before a program. I used the sharpie-in-a-collet technique, but found that as the spoilboard gets chewed up, the sharpie doesn’t mark well.
Seems like the solution to this is to set up the sharpie to something similar to a drag knife. I haven’t been able to try this yet.
Currently, I’m just posting the relevant toolpaths that run into the spoilboard and following them with a sharpie in my hand.
Thank you for your reply. I have actually purchased to the stubby Sharpie’s but my setup
requires the router to reach to a higher Z position than it apparently likes. I have done exactly what you describe to mark the spoilboard, but I am actually trying to mark the exact toolpaths to the back of my material.
I carve signs out of 1/8" white melamine and use a tape and glue method to attach the large 32" material to my spoilboard. Because this method uses a lot of tape and glue I only want to apply the tape and glue to the areas that I need to keep intact during the carve. That is use my tape and glue sparingly.
So marking the spoilboard is the easy part, but marking the back of my material to match the tape and glue locations is my challenge. Hence the Sharpie method. I hope to lightly two face tape my material to the spoilboard (exposing the back side) in order to mark the identical locations of my spoilboard layout to the back of my material.
Thanks again,
Ray
P.S. I have found that the tape and glue method using water based contact cement is a cheaper alternative to CA glue; just suggesting.
Your workflow sounds very similar to mine. I also find many instances where tape is used, but I have found screwing the work down is generally preferred, or a combination of both.
I use a workflow outlined in a thread I posted a while back that you may find useful.
Sounds like the issue might be your safe Z setting. When you run your program, the machine will try to go up to the safe Z height for its rapid movements. If your Z zero is only 25.3mm from the Z limit, and your safe Z is greater than 25.3, you will get the Z limit error.
