E-Stop Disabled
Just had to use my E-Stop on the 1F Controller and found that it didn’t work so ended up resorting to hitting the E-Stop in the software window.
When I checked the I/O Configuration settings I found that the E-Stop was disabled. Firstly, why would that be so and secondly, how do I enable it and which options to set (Normally Open or Normally closed) and do I need to wire anything up to achieve this.
Cheers … Dave
I should think you’re seeing an external E-Stop that would be enabled through a breakout board, not the one on the controller. Chances are the one on the controller is not connected inside the box, so I would reach out to Onefinity to see how it should be wired.
