I have an elite series Gen 2 redline foreman machine that has been very unreliable due to Redline spindle error 12 faults. Previously in August this year I was flattening my spoil board and in the middle of the tool path the spindle just turned off and error 12 was on panel. I shut machine off and checked all connections, no problems identified. Restarted and fault was not active I would turn on spindle and the spindle sounded like it was running but the output shaft would not turn. Contacted Onefinity technical support and they forwarded my problem to redline support. Redline support recomended a factory reset with programming. I completed and the spindle started working and function seemed normal. I was able do do several projects then I switched over and started using Jtech laser and after switching back to Redline spindle, the error code was back. I went through the factory reset and it started functioning again, but this time it was only for a short time less than 5 minutes before the error code returned. The spindle would sound like it was spinning but no shaft rotation, if you spun the shaft some by hand it would start spinning normal and if you went above 1500 rpm then it would immediately trigger an error 12. I have also noticed before error code started the spindle was making a high pitch squeal that would come and go. Does anybody have any suggestions? I am new cnc user and I am hoping that this unreliability of this machine is not normal and there is something I can do to resolve this error. I will attach a short video so the squealing of spindle can be heard.
Thank You
