The Elite series with the Masso Touch controller is designed with the mount for the screen on the left Y rail.
Some users may want to mount their screen elsewhere, which means removing the mount. This will cause the mounting bolts to protrude out toward the Y rail gantry block, preventing the Y rail from homing.
See Picture:
Users who want this have two options to remedy the long bolt issue:
- Acquire shorter bolts (X2): M5 x 70mm Long
- Use washers on the bolt heads that are the same thickness as the screen mount.
