I’m getting a Error message
error Planner Planner.py.383 Z axis position is less than minimum
While executing GCode block G1-0.2519 F20
Its my first file. Should I just create a new file?
I’ve homed the machine and zeroed the workpiece.
You need to Home then Zero your machine. If your file is within specs of the materials then once you Zero and re-run the file it should work fine.
-Alex
