External WiFi Antenna Mod
It is possible, though difficult, to add an external WiFi antenna to the Onefinity Controller. I’ll show you how in the video. A better solution might be to replace one of the panels of the controller box with a non-conductive material. This should also allow stronger Wifi signal reception.
Hey Kevin - that’s a great video - well done! Thanks for the explanation.
Excellent video, thank you for the insight! Although I’m not afraid of much when it comes to soldering electronics, I believe I may have to pass on this one. I’m still scratching my head at the “zero ohm resistor” concept.
