Michael why do you insist on making me look so bad!! Seriously, your setup looks great and detailed, well done!
Thank you for sharing your work. Is that a contactor for controlling power to the spindle?
I love a well laied out panel & raceway! Looking really good.
You are amazing ! That is a thing to behold. Could you share the lug #s on the vfd and what it is controlling?
Waiting for a few fuse holders and 5v power supply yet so not quite finished.
That looks to be a very thoughtful and organized installation. May I ask what safety circuit you are using - is it tied to the controller estop? Also, were considering some kind of protective cover over the electronics given their location? I am looking forward to seeing the continuation of this project - I appreciate you taking the time to share your progress.
Tom
I have an estop on side of vfd stops spindle dead. And the normal estop on 1f
Going to put a dust cover over the top of it mdf probably.
Vfd mounted now with pot speed override for manual speed control also configuration of other switches like spindle coolant over ride vacuum override, these all come on with m7 & m8 in the gcode but its for overriding it.
VFD turns off 60 seconds after 1f power down now avoiding spikes in the circuits.
1f will have its own power supply filter when it arrives.
I thought I spotted a timer delay dial on one of your DIN rail components. I find this part of the process exciting.
That is exactly the way I want my set up to be alike! Thanks a lot for the inspiring pictures!!!
Love the updates - it is great to see the innovation and build progress. I am currently fine tuning and testing the fit of the design for my limit switch mounts. How did you attach the two printed components to the aluminum blocks? Also, what type of sensor/switch is contained inside the little black box?
Its purely a micro switch grounding pin 3 and 5
I superglue them on give the metal a good clean and they stick fine.
