Gladiator GearWall
I’m curious if, by chance, anyone has tried using this as a spoilboard:
https://www.homedepot.com/p/Gladiator-48-in-W-Garage-Wall-Storage-GearWall-Panel-2-Pack-GAWP042PBY/204648992?adobe_mc=TS%3D1737023243|MCMID%3D44387819813130261775113332581113288878|MCORGID%3DF6421253512D2C100A490D45%40AdobeOrg&mboxSession=f7c2e683-30d5-435b-93e2-6b0a2eb17baa
Little pricey maybe, but you’d have enough for two full spoilboards for a woodworker though as well. That and you’d save time carving groves too.
So, has anyone tried this yet? Thoughts on if it would work?
Thanks,
Misury
Hmm, interesting find! following this thread now.
I use these on my workshop walls. The slots are not compatible with the typical t-slot clamps used on spoil boards. As far as I know, the slots only support the proprietary hooks and hangers provided by Gladiator, and they don’t make a clamp.
Awww, dang. Would’ve been great if it worked. Thanks for your reply Roger.
Mike
I would still try it out. Shouldn’t be that big of a problem creating those nuts, treading them to smth like 1/4-20
Heck, I would even CNC it from 3mm brass :slight_smile:
although it depends how much spacing is there.
Misury,
I wouldn’t recommend using the GearWall as a spoil board. I have used a similar product as wall racks. The slats I used were made of PVC. PVC, when heated, can emit fumes that are not good to breathe. No matter how careful you are, you will cut into the spoil board. Also, the PVC will become brittle with age.
Another drawback is the price. The GearWall is about $65 for 48" x 24" coverage. 48" x 96" MDF is about $50, which gives you two 48" x 48" spoil boards. An MDF spoil board can be customized to your liking and the way you work.
I like the waste board that Morgan showed in https://www.onefinitycnc.com/onefinity-projects Ep3. Download the zip file.
You can also see this in the forum at Dovetail Waste Board.
I think that you will find the dovetail spoil board to be more versatile and less expensive in the long run.
Dirkus (Dirk)
