Has the laser homing issue been fixed?
Trying to fire my laser using the mdi codes but no luck after it has been homed. It is now almost June Has this problem been fixed? I can fire the laser if I hit the gear button and un home. I’m looking for a fix.
yes, as of 1.0.9 firmware.
Well it doesn’t work on mine. my machine which arrived late Jan came equipped with1.0.9 I have did all the cable ,connecter check with my meter on DC. Still no luck any one have a fix?
What setting do you have selected in the “tools” menu?
It is on Laser (j tech,ect). disabled
Try switching to ‘makita’ and hit save and try the mdi commands.
It Worked!!! I homed the machine then used the m3 s10 it fired right up with the machine still in home mode. Thanks thanks again you Maple Leaves are awesome… L.Lee
