Help please, I set Home and zero, I send the file to cut start cutting somewhere else.
You’ve “zeroed” the 1F and you set the zero start position on your work piece then the cut is off location (or off) the work piece, correct?
One place to look at is to make sure the start location in your software program is the same as the physical ‘zero’ location you are using for the work piece. I use Vcarve and it allows for the start/zero position for be in a corner or center of the work.
Check to see if your file is offset from zero. I’ve run into that and it was frustrating until I found the little checkbox for “offset zero”.
Yes these help to fix my problem,
You guys being so helpful,
Thanks very much.
Frank - did you get things working?
