So I have been spending hours trying to cut projects after I upgraded only to have it crap/bug out on my pieces. It randomly does a low cross cuts into the the project at the end, completely running it. when I have the G-code set to .5 above the home point. So it should bring it back up above the piece but it does not.
It also will not allow me to raise the Z at the end of the file as if someone hit the stop button. All the Also when boxes in the XYZ home columns gray out, not allowing me to raise, lower or move anything. They will reset after I’ve reloaded a file 3 or 4 times.
Why would it be doing this?
I use Vcarve pro
