Homing and x motor alarm first setup
Once I start the muscle it has the regular double tap home and e-stop yellow flashing. No problem to remove the e-stop flashing but when I double tap on home I get the alarm x-motor alarm. I then go to my F1 screen and the x-axis motor alarm is high. I get rid of it by spacebar then go back to my f3 and it’s still x-motor alarm flashing. I then hit home and I now have alarm homing error flashing red and alarm x-motor alarm flashing red. Thank you for any help you can give me
Another interesting thing is that when I go to my f3 and jog it will only go about halfway back. I did zero out everything when I honed it
A couple things to check… Check your soft limit values and make sure they aren’t less than your cutting area. Make sure everything is square. Before fixing the rails to the table (or remove them to check this) fix the front of the rails, leaving the back unattached. Run the gantry to the back. then affix the back of the rails. Run it around and make sure there is any binding or errors. If that is all good, then you can check if the motor is the issue by first confirming all your connections are solid then you can swap an x motor with a y motor and see if the error moves to the other axis.
