I have the Gen2 Foreman with the QWC table.
my spindle overhangs the front of the table by about 2 inches, i also have the ATC so I can not simply extend the MDF so it overhangs but this mean I can not cut a full 48x48 sheet. i loose that 2inches off the front so i have about 46 inches of Y-AXIS travel
yes/no/maybe
The QCW allows fairly quick disconnect from QCW and move to the side - just remember to remove auto tool changes from your cuts
You can mount the ATC to your bench using a custom mount so the top of the collets in the ATC are just below your spoil board - you obviously have to make sure you still have enough Z travel and you may lose overall workable Z to get it to go this far down in one spot. This allows you to slide a 4x8 sheet directly over the ATC and tile it with no issues (other than not being able to use the ATC
I have a Gen2 Foreman with QCW table and legs. Could you expand on how “vertical clamping” might physically be configured on that setup, or am I missreading your statement?
Anything on the front of the QCW would have to be custom made - but that insert itself could easily mount to the front (Extend 2 boards over the QCW by 3/4" to screw directly into the vertical frame and you build something off the bottom to hold it steady and you are in buisness
The spindle will cut quite a bit over the front edge of the QCW
Thanks for the reply, vertical clamping expands the machine’s capabilities a lot. I’ve still not decided if I’ll employ the “Y” axis vertical mount yet, but that looks to be the most useful to me.
As to utilizing a mount (X direction) at the front of the QCW, I measured only 1-1/4" overhang spindle’s centerline to the QCW frame (using my chuck mounted laser on my Gen2 Foreman). I don’t see how that would really be usable.
My question was just a reaction to 1F’s indication the overhang was usable for vertical clamping.
You mount the vertical board used for clamping even with the front of the QCW, so any board clamped to it has 1.25" of travel essentially, so for 3/4" wood, you would be able to make dovetails and have 1/2" extra Y axis room
If you use 8/4 and wanted to make tenons or mortise, you could easily get there with 1/2" on each side and the 1" in the middle being well within the spindles ability to reach
