tjp52
(Tom)
1
- Turn on CNC
- Tap “Home All”
- Tap “Jog Home” (Round target in center of jog control)
Result: Machine locks up… no further movement can be made. 100% reproducible
Environment:
HMI Controller
FW: 1.6.3
This is not a major crippling effect…it was just discovered by accident. The referenced clip below clearly demonstrates the issue.
Video clip is here
OnefinityCNC
(Onefinity CNC Official ✅)
2
Certainly looks like a bug (an doesn’t practically make sense as your returning to the same spot it’s already at
We’ve reproduced it and will get with the @RTCNC to implament a fix.
PS: You can push the ABORT button in the upper right to get out of the hung state.
tjp52
(Tom)
3
True…doesn’t make sense except if you might have been side tracked and just wanted to verify.
It could be a bit more gracefully handled…either do nothing if already at home or just ignore.
