Jtech Laser Not Firing
I’ve sent this issue to both Onefinity and JTech, but with the weekend here I’m hoping a forum member can get back to me before they do on Monday…
I’ve just installed the 7w+ Laser kit on my new OF Woodworker Pro. The laser fires full blast if I set the JTech switch to manual, but won’t fire when under software control - neither Vectric files nor from MIDI commands.
I have 1.6.6 on the BB controller. I have Laser selected under tool type. Using a digital multimeter, I have verified that I get voltage on the laser out of the BB, as well as voltage thru the cable to the JTech module and voltage on the JTech module terminal block. Jumpers on the JTech are set appropriately - J2 voltage 12 volts, J12 non invert (changing to invert doesn’t help), J13 PWM.
If I use MIDI commands to try the laser - M3 Sxxx the laser will not fire no matter what the Sxxx value is even though I can see voltage at the H2 terminal block and on the cable end that plugs into H4. But, as I said, the laser is working and fires if switched to manual mode.
If I execute a gcode test file of a fill on some text, my multimeter on the JTech bounces like crazy - signal voltage is changing so quickly the multimeter cannot keep up.
Any ideas? I’m stumped….
Did you look here
Yes, but it was of limited help, especially since that posting is 4 years old and the firmware and post processors all handle Jtech lasers natively now without jury rigging another tool configuration.
@jnordyke did you ever get this working? I am having the same issue and I even tested known files that worked prior to me updating the controller.
Jtech Laser, Masso - won’t turn on through controller but will run from gcode
Nov 2024
9h
post by Loopback77 on Nov 9, 2024
Loopback77
1
Nov 2024
I have a Masso controller and a Jtech laser. I can’t get the Masso to turn the laser on manually with any power level through the Masso controller.
However, if I load a gcode file into the Masso for the laser, it works just fine.
The trouble is, I can’t set an x and y zero precisely because I can’t turn the laser on with low power to set it.
Clearly everything is set up correctly because I can run jobs with the laser just fine. But if I give it a sXX m3 command, the yellow laser button comes on, the controller states that the laser is on, but I get nothing.
This is a new problem. With no changes to wiring or configuration, I was using the laser without issue for the past several years.
Any suggestions?
93views1link
Summarize
12 months later
post by Stefan-H on Nov 8
Stefan-HStefan Hampden
Nov 8
I know this is an old post but hopefully can help someone out with a similar issue
I just upgraded to 5.13 and am having the same issue with m3 & the GUI “laser” button not firing the laser manually when in tool 111. Reading a bit on masso’s site m4 is listed to “laser on immediate” while m3 fires “laser output enabled with motion” I’m guessing this changed between my last version (5.10 I think) and 5.13
The odd thing is the laser on button must still be using an m3 because it highlights but does not turn the laser on till there is x-y movement (apparently via g-code as jogging it with an m3 on does not seem to turn it on either)
docs.masso.com.au
M03 – Laser output enable with motion
last visit
1 month later
post by thudthud 9 hours ago
tada
This is the first time thudthud has posted — let’s welcome them to our community!
thudthud
9h
Thank you. This allowed me to get my new laser to work from Masso MDI as the M3 command wouldn’t work even with putting a G1 in front of the line. M4 works
My issue was a bad laser head which J-Tech promptly replaced
Thank you, I hope mine is not any bad hardware.
Is there any way to tie the M4 command to the GUI “Laser” on the screen? I looked through all of the Fx screens but nothing stands out.
I have same issue, how was your issue resolved ?
Jtech replaced the unit
