Kreg 44x64-in table & Journeyman X-50 & MDF
Hey Jim,
you can mount any of the Onefinity’s rails with the motor pointing in the other direction, e.g. X rail with motor on the left (instead of right), or Y rails with motors pointing towards front (instead of to the rear). If you do this, you have to check the option “reverse” on the corresponding MOTOR page under “Motion”.
Here is a video from the manufacturer:
So if you want to save space, you could flip Y rails so the Y motors point towards the front, since this space, that is in front of the machine’s dimensions, is required for the dust boot anyway.
Here you can see that the dust boots protrude beyond the dimension of the machine:
(What is the Best Dust Boot for the Onefinity? )
[/quote]
Just in case you build an enclosure or a flippable table top, you can also reserve some more space in case you retrofit other motors later. Motors with encoders (closed-loop) or a brake on the rear can be much longer.
