Masso Pendant with both estops working?
Can anyone help me with wiring instructions to get my Masso pendant Estop working? Has anyone successfully gotten both Estops working?
Check out the documentation from Masso for wiring the MPG pendant. It mentions having to move the existing wire on the Masso from Estop2 to Estop1.
https://docs.masso.com.au/wiring-and-setup/setup-and-calibration/mpg-pendant
Thanks Brian…I have seen the documentation, but I want to be super careful, as the actual Masso has 2 wires in Estop2. The documentation only mentions 1 wire, I believe. Looking for someone who has actually done it, and to see if they moved both wires, or…? And then the next question will be how to do it (get both pendant estops working) with the new z braking motor, given all the warnings in the docs re braking motors and estops…
Check out the following post on setting up a wireless MPG. If you look at the wiring diagram, it was necessary to move 1 wire (black) from Estop2 to Estop1 and leave the other wire (green) on Estop2.
