Thanks. I think I have 1.0.9 and 4 new sd cards. I did try to reflash 1.2.1 three times each time with different results. So Strange.
Hi @wolfeman : may I know what do you mean by different results? And did you get a chance to try 1.3.0 alpha?
I loaded 1.3 alpha, ive been stress testing loading and deleting files. only snag that occured was on one file the 3d image didnt generate. I deleted the file and reloaded and it worked fine.
is this version safe to carve with?
Hi @ahandeman : currently it is in preview to test the Gcode issue and rest of functionality as is from 1.2.1. I believe if Gcode is working then it’s a safe to cut.
Thanks for your feedback. Let me know if you have observed anything new in this release. Looking forward to hearing from you.
Hi. 1st just to let you know, I am not a developer or even employed in the Computer industry. Just a simple person that got stuck in this awful loop of machine not working after upgrade. I finally got back to version 1.0.9 and all of my problems went away except for the joystick which may have been coincidental with the timing of the upgrade.
I have not tried 1.3.0, after looking at the folder I don’t think I would know which one to even open. They all seem to be small files. I will have to look it over better. I am worn out and have project out the wazoo that need to be made so for now I will leave well enough alone.
As far as different outcome from different flashes, one time the controller would read a file, then the next time it would not. It would run one file but not even load the next file that I tried to load both with and without Wi-Fi. I did a video of a lot of the problems. When I get them on you tube I will send you the link to the email address I have for you. Way to hard to explain in words. It will be a few days. Thanks for your input and watching the posts and trying to keep up with them. Very much appreciated.
“ahandemon” That is great news. Maybe a breakthrough. Not sure what stress testing is but sounds like you are putting it through it’s passes. Good luck.
Agreed. This is so painful.
Thread Closed as 1.3 Alpha has come out. Anyone having issues please load 1.3 and respond in it’s appropriate thread.
1.3 superseded this firmware.
