Ready for first pour
Ready for second cut
I take all the tape off after each pour
The problem is with this method the machine is tied up till the second cut is done, so, I cut and pour number one at end of day and then cut and pour number two the next day around noon. The marker lines in the first pour are to give highlights through the epoxy,
The way I designed the pattern leaves .004 of wood between the ppours which you wouldn’t think would dhow but if you look close at the two tone fish you can see the wood lines between the pours. Who’d of thunk?
I use center (16X–16Y) for layout and use machinist gauges to set Z. Makes turning off the machine and restarting the next day a snap. Set limits then go back to 16X–16Y and set them as ‘0’
