My wife has had Boston’s for many many years. She loved the post
Dave
That is really nice Dog… what did you carve that in? From one solid piece? And 18hrs straight or pauses in between? Thanks for sharing
One solid piece of basswood. 23x14 1 1/2in thick. It still has its live edge on the top and bottom. Thinking about putting some led lights in that part to light it from the top and bottom. I broke it up into two days pausing it at night when it got too late.
Do you plan to trim off the top and bottom? It looks much thicker. Got to get me some Basswood! Thanks
Did you stain the board before or after?
I stained after and then sanded down the high parts… This almost took all the grooves down so it feels almost smooth but retained the color in the deeper groove parts. I used two small pieces of maple glued together just because it was some scrap I had laying around. It probably would have been more even had I just used one piece of wood. Oh little tip… I found using a brass brush brought out more detail in some of the parts that came out darker because of the thinness of the grooves. Also I will look for wood that has very little grain showing.
I have the solution to filters being clogged on shop vacs. Buy the bag that goes inside the shop vac. Worth every penny. It protects the filter and you get more consistent suction and airflow for many times longer than without using the bag. Also, it makes emptying so simple. And it helps the exhaust output less dust due to the added filtering of the bag.
I really do like this . I would like to make one as well, did you create this or find it some where,if found would you please share where?
Thank you
I found it on 3dwave.us
That looks like a high quality carving~ well done! May I ask the details on software and tooling?
Thanks
Roughing pass with a .250 EM at 300IPM
Finish pass with .125 BN at 200IPM
Profile cut with .125BN 40IMP
Makita router set at 2 1/2 or so.
Use VCarve Desktop for software
Very clever design Ty. They look great!
Fantastic work. I am completely a newbie and would love to pick your brain on your process.
