Probe XYZ sequence failure, X continues
I’ve just gotten my machine set back up in a new shop and I’m trying to probe XYZ for my first project but getting a failure message that says, “could not find the probe block during probing”
When I run the sequence after I touch the probe and initiate it, the router just moves right until the error message appears, it never attempts to touch the sides of my probing block. I already checked for dust or grease causing a bad connection and that doesn’t seem to be the problem. Anyone run into this before?
(also i know you can’t probe with a surfacing bit, I’m using a 1/4 end mill)
Thanks for the help!
Try testing the connection.
Go to the F1 screen, and touch the probe magnet to the probe block, and confirm the status changes from low to high.
If that’s good, try probing the Z only.
Retract the spindle, and start the probing sequence, and when Z starts to move towards the table, touch the magnet to the block, and make sure the machine registers the connection.
If that’s good, try probing the x-position, but again just touch the magnet to the block while the machines is moving.
If that works… but you still haven’t found the problem, post more info so we can get a better understanding of the steps your taking. A video would be good… not sure if you are able to post a video on the forum yet??
Thank you so much for your support.
It sounds like you’ve already checked for debris, so we can rule that out. Here are a few more things to consider:
  1. Check Connections: Ensure that all connections to the probe and control unit are secure. A loose wire can prevent proper communication.
  2. Probe Calibration: Make sure your probe is calibrated correctly. A miscalibrated probe might not detect the block properly. Check your machine’s manual for guidance on calibration procedures.
  3. Software Settings: Double-check your machine’s software settings. Ensure that the dimensions for the probing block are correctly entered in your control software. Any discrepancies could lead to failure in detecting the block.
  4. Firmware/Software Updates: Ensure that your machine’s firmware and the control software are up-to-date. Sometimes, an update can fix bugs that cause issues like this.
  5. Test Different Tools: Although you’re using a compatible end mill, test with a different tool to rule out any issues with the current tool.
If none of these steps resolve your issue, reaching out to the manufacturer’s support or community forum may provide further insights. Good luck!
