I have a 1F X50 Journeyman.
I wanted to add some dowel pin holes to my spoil board to use as locators.
I keep getting this error and I just dont see where it is.
I am drilling some holes but the error is always the Y axis.
I am working in imperial.
410mm is only a little over 16".
I dont see it can you experts know what the issue is?
I am using Firmware 1.2
seems you have an Y maximum soft limit set to 410 mm. On Journeyman, it should be 816 mm (MOTORS → Motor 1 → Limits → max-soft-limit).
Maybe you should reset the machine’s configuration to the correct default (ADMIN → Configuration). But in case you entered custom values, make note of these and make a configuration backup since you loose them when resetting to defaults.
Did the following test. using V Carve Pro 11.5. set sheet size as 32 H x 48 W and .75 thick.
Place one (1) hole at 16 inches in Y and 24 inches in X. Take to machine to see if it would cut it. Than get error message 2.
It seems that on your Onefinity Controller you have an Y maximum soft limit set to 410 mm. THIS IS WRONG. On Journeyman, it should be 816 mm (MOTORS → Motor 1 → Limits → max-soft-limit).
