Question for the Experts Why Error Message
Hey Wayne,
seems you have an Y maximum soft limit set to 410 mm. On Journeyman, it should be 816 mm (MOTORS → Motor 1 → Limits → max-soft-limit).
Maybe you should reset the machine’s configuration to the correct default (ADMIN → Configuration). But in case you entered custom values, make note of these and make a configuration backup since you loose them when resetting to defaults.
