I went to run a new project, and the Onefinity screen turns on however there is nothing but a barely can see blue, after startup, when starting up it does a few things it did as usual but stops short of going to the operations screen, and it goes to the light blue close to black screen, …
try flipping the usb c cord around 180. They seem to have a ‘side’ that is good and one that is not as good.
Here is an update it turned out to be a firmware issue when the screen had went out later the machine stopped running and this repeatedly happened I would turn it off unplug everything restart and this would happen got from where I update sent opened up controller pulled out SD card reflash with new firmware installed SD card back hook up everything machine works fine now my only question is is this going to continue happening it interrupted a project I was in the middle of
