Set up in inchs runs in mm
i set up everything in inchs on the masso controller x y and z once the machine shows it running in mm cant figure out how to keep it showing inchs while its runni g
I had a siimilar challenge. Not sure what softtware you are using. I am using Vectric Aspire. I found that when I installed the post processor I had the inch and mm versions installed. So, I would create projects in inches but when sent to the post processor it would change to mm. For some reason the MM version was preffered by the PP or by Masso. Never really figured out what the cause was, sofware or human error. I just unistalled the MM Post Processor version and the problem went away.
Have you set your Masso for inches also?
Is your G-code program in inches or metric? Look at it and if it is good, then it has to be the machine. Also check to see if you have G20 or G21 in your code.
Everything is in Inches as all of my bits are imperial measure.
