Solved My Onefinity WiFi Issue – No Hardware Modifications Needed
I was having trouble with WiFi reliability on my Onefinity controller and didn’t want to modify the internal hardware or run new cables ( I did look Ruairisdad excellent modification). After a bit of experimenting, I found an easy fix that requires no technical skills and no modification to the controller itself.
I used a TP-LINK WR802N travel router, set it to Client Mode, and connected it directly to the controller’s Ethernet port. This effectively converts the wired port into a wireless connection, allowing the controller to connect to my shop’s WiFi network without any issues.
Now, I can access the controller over WiFi reliably and didn’t need to open or modify the Onefinity hardware at all. A quick, plug-and-play solution!
Step-by-Step Setup Guide
  1. Power the WR802N
    Plug it into any USB port or wall adapter to power it up.
  2. Connect to the WR802N Setup WiFi
    Use your phone or computer to connect to the WR802N’s default WiFi (network name and password are on the device).
  3. Access the Setup Page
    Open a browser and go to http://tplinkwifi.net or the default IP address listed in the quick-start guide.
  4. Log In
    Use the default username and password (also on the device) to log in.
  5. Set to Client Mode
    In the Quick Setup, choose Client Mode. This mode allows the WR802N to connect to your existing WiFi and output a wired Ethernet connection.
  6. Select Your Shop WiFi Network
    Scan for available networks and select your shop’s WiFi. Enter your WiFi password.
  7. Save and Reboot
    The WR802N will restart and connect to your WiFi.
  8. Connect to the Onefinity
    Plug the WR802N’s Ethernet cable into the Onefinity controller’s Ethernet port.
  9. Test Connectivity
    From your computer, connect to the same WiFi network and open the Onefinity controller interface as usual.
