Stability during carves... acceleration vs. jerk?
I have a 1F Elite Foreman. Anyone have any advice on how to help stabilize the Z axis assembly during carves? I have checked for loose bolts, etc. and everything is good, yet I continue to have issues with tool marks during carves. For example, if I do a profile cut and use tabs, the end mill will leave ‘dents’ in the edge of the piece at the beginning and end of each tab. Additionally, when I use my Jtech laser, the laser jiggles when the machine is changing directions, and it causes squiggly lines in the engraving. I have already reduced the acceleration settings to 1/2 of factory settings, and have set the PPR according to the most recent guidance from 1F. It did help some, but not enough.
I have read other posts which seem to indicate a difference between acceleration and ‘jerk’ settings on the Buildbotics controllers… but the MASSO only offers a setting for accelerations settings as far as I can tell.
Another example is the end mill will leave circular indentations at the bottom of a pocket. It’s as if when the Z axis moves up and down, the sudden start / stop of the motor causes the spindle to flex up and down if that makes any sense. I have the PWNcnc ATC spindle and I’m starting to wonder if it’s just too heavy for the machine.
Thanks,
Mike
One thing you can try is go to 3d tabs. It should eliminate the tool marks.
Thanks Gary… I will definitely try that… and it makes sense. Don’t know why I didn’t think of it.
