I use the t track just to hold down a temporary wasteboard.
The wasteboard always gets cut into, it has to be easily changeable.
Then I use ca glue and blue tape to hold down the stock.
The glue/tape method works PERFECTLY.
I am afraid to use t tracks until I go thru the learning curve. I could see me routing to deep and hitting the track.
I found some tape I want to try. Accidentally bought this and tried it to hold some wood in place for a project I was working on. It is removable but not easily. It is very strong. I had to put some elbow grease on it to break it apart. We now use it all around the house if we want temporary but a very strong bond.
https://www.amazon.com/gp/aw/d/B07ZVDBCZV?psc=1&ref=ppx_pop_mob_b_asin_title
I had the same fear and early on, did make some errors. But all the errors were my not paying attention to details. I have started to zero my Z off the waste board. Taking this approach, it forces me to use calipers to dial in the size of the material.
Here is the tape I and others use to hold down the parts during machining. Its pretty cheap and it comes off the pieces without leaving any glue behind. Iāve been happy with its performance.
I have both the 1" and 2" wide for different applications.
-Alex
Thanks for posting! Added to my shopping list (that never seems to get shorter!)
Agreed - Good prices on the t-Tracks, but shipping from orange aluminum is costlyā¦30.00 to ship to North Carolina unless I spend 100.00.
I ordered these from e-bay. They are 24" but can take 1/4 inch bolts as well⦠not sure the need for t-track the entire 32 inches is needed as I would most likely stagger my clamps anyhow. Currently using double sided tape - seems to work well with MDF and Pine - but DS tape is $$
While the machined aluminum clamps are nice, inevitably you will place one in the wrong location of a tool path and your wood cutting bit will NOT be happy with what you did. Donāt ask me how I know this problem.
I plan to use T-Track for my second spoil board. Iāll make low risk of damage mistakes so I can just break bits to start rather than destroy my tracks.
p.s. Congrats on your retirement from USAF, Iām right behind you!
What do you use for hold downs
I use a combination of painters tape and CA glue and the Rockler t-track clamps. 70% of the time itās painters tape and CA glue only.
I plan to use the tape and glue technique during my ~first year of learning.
Hey @waynecottle I use a varied set of clamps for my T-Track, 95% of them are DIY solutions based on the oops clamps but made of wood strips. I also have some Rockler clamps that I have modified to work with my extra 3/4" MDF sacrificial board. I also use double stick tape to hold down parts that are not very clamp friendly.
-Alex
For what its worth, Iām going to give a dovetail spoilboard a try a la https://www.youtube.com/watch?v=KJABIIzeI_I
Take it with a grain of salt thoā¦my Onefinity is still in boxes while I finish a work table.
-Mark
Iām going t-track, and putting the track ābelowā my wasteboard, and having the wasteboard overlap the t-track. Itās supposed to help prevent the clamp from pulling the t-track up out of the slot (MDF doesnāt hold screws real wellā¦).
I this picture, nothing is screwed or glued down - everything is loose. And, the clamp tightens up just fine.
Continuing the discussion from T track? Or no t track:
My base is 3/4 plywood, then I screwed down the T trac which are 1/2 inch thick, and then installed 3/4 inch thick MDF between the trac. I made some clamps by cutting some hard wood 5.5 inch long by 3/4 inch thick by 1.5 inch wide. At each end I cut a 3/8 inch by 3/8 inch notch. In the middle of each unit I cut 1/4 inch wide slot in the middle about 3.5 inches long. This lets you buy the standard 1/4 hex head bolt and use knobs that can be purchased a lot of places.
I like the numerical grid markings. Do you have them up the left side too? Would you be able to tell me the with of the slats and share the file?
I am using 3/4in mdf sitting on top of a larger sheet of 1/2in mdf 33x40
