Vcarve misrecognizes a crv file as "unsupported"
I have a design in Vcarve that I would like to reuse, but the software has decided it is an “unsupported file type.” Presumably the file is corrupted in some way. Has anyone had experience with this? Is there any way to uncorrupt the file or extract the data?
File
Pinion.crv (1.2 KB)
is attached
Thanks!
Opening this in notepad shows that its a very different from a standard crv file when I compare to some of my projects. It looks to be simply a set of data points used in the version 8 gear generator gadget inside of Vcarve. If this is only a gear you could just open it in notepad and carry the values over to the gear gadget on a new file?
