Woodworking making awful noise
This is a copy of the email I sent to tech support. I’ve sent it twice, so I don’t know if it’s getting through or not. If I get an answer there I’ll note it here. I’m not trying to call anyone out…I just need some assistance.
My machine has developed a problem when moving on the X-axis that it makes the noise in the video. Also, sometimes it moves in the wrong direction as I’ve tried to show in the video. This only happens about 75% of the distance from front to back on the y-axis. When I move to a point further forward, this doesn’t happen. The second video shows this. It’s either on or off, based on a point on the y-axis. I have tried squaring the machine, tightening the couplers, and everything I could think of. Do you have any suggestions?
Thanks,
Email responded to!
Hi Paul,
Thanks for your email.
It’s 100% a wire issue. This faq will help you diagnose which one it is.
When I pushed the x-axis motor wire harness into the clip it worked…for a few seconds. So I think there’s probably a short in the wire. I’ll order a new wiring set.
Thanks for the help.
Glad to help and glad you found that!
Good evening Quesohusker I have several questions and I am new to the forum. First, how do members email each other directly?
Click on the icon (avatar) next to the user’s name and select Message.
