AJKremer
(Andy Kremer)
August 19, 2025, 2:23pm
1
Good morning!
I have an OG Woodworker x-35, I am in the process of setting up the match fit waste board, however, when I go do measure the max X and Y, the X axis only registers to 20 in (??)
I am on the current version (1.6.4) and have reset and restarted multiple times with the same outcome.
What am I missing?
TIA!
OnefinityCNC
(Onefinity CNC Official ✅)
August 19, 2025, 2:47pm
2
Reset the configuration to your specific machine:
X35 woodworker
Z16 z slider
Occasionally, there may be a time when you need to reset the machine back to factory defaults. Here’s how to perform a configuration reset. (machine not working correctly, machine cutting shrunk or stretched, ipp rail upgrade sizes)
Please note, resetting the configuration will change any custom values you have entered (i.e. probe size, stall homing settings). Please make note of these BEFORE resetting so you can input them back in once reset.
Always ensure you’re on the latest firmware (as …
AJKremer
(Andy Kremer)
August 19, 2025, 3:04pm
3
Sorry, this still didn’t fix the issue.
Once reset and restarted - jogged to max X and it still registers 20.29 in
OnefinityCNC
August 19, 2025, 3:23pm
4
Did you do an update to a IPP rail? If so, then you have an x50 rail, so you’d choose x50/pro woodworker and save and restart.
Email support@onefinitycnc.com if that doesn’t fix it.
