Good evening group, I am doing my first ever cut on my X-50. Surfacing the spoil board. It Is so exciting!!! But … It stopped short on the “Y” axis! About 10" short then re-homed (it surfaced the majority of the surface without a hitch). I am a little frustrated, but it is so exciting to at least get the machine up and running, I have had it since before Christmas. ANY suggestions? I am using a program to surface the spoil board, and all was going great until it was finished.
Could be a number of different issues. Where is your datum/origin point set in your design program? Are you setting xyz zero from same location? If you purchased the file, are you creating the toolpaths or running from a toolpath file that came with your purchase? Could be that is set for different sized machine. If you need help, reach out to me in FB messenger
Hey Russell,
as Mitz already suggested, if you use a program, you got to check its parameters. Did you use the correct machine model workarea size?
What are you meaning with “re-homed”? Are you talking of an error that aborts the program? If so, what is its error message?
