Just assembled my Elite Journeyman. I noticed that the Y rail gantries only have about 1/16" clearance over the table top. Is this correct? Seems like there should be greater clearance. I notice that the Foreman assembly instructions indicate adding a riser block under the Y rail bases. Why does the Journeyman not have the same risers?
The woodworker has about 1/16 as well, pretty close
pat
Hey Brian,
because the Journeyman has the 35 mm rails on Y, while the Foreman has the 50 mm rails on Y (see difference). Only on the latter it’s the carriage that protrudes downward the most, and not the feet.
Thanks for the replies. Appreciate the photo @Pony . That’s what I was thinking of doing. My concern is that it could be possible to get a chip under the gantry that could cause a bind. Maybe that’s a bit of an extreme scenario. But I was also going to ask if there would be any downside to putting a plywood spacer under the Y bases. Looks like it would be Ok.
Ideally they would be machined metal pieces, but wood works, especially hardwood.
Pony
I did the same with a piece of Maple. ![]()
We sell them here: https://www.onefinitycnc.com/product-page/riser-blocks-for-y-b-feet-spare
They are only included with FOREMAN machine sizes.
