I am new to this machine and forum – When I execute a file even after using the probe or not the machine raises up and cuts air about 6 inches off the work. I also downloaded the OneFinity test file and it does the same thing – any thoughts?
Hello Kepink and welcome,
Have you reset the default configuration?
How To Reset The Configuration To Defaults (BB Controller)
It is also good to get in the habit of doing a check after the tool touch off.
After I use the touch probe, or even after I use the paper method, I move the tool away then bring it back to the origin X0 Y0. Check that that looks sane. Then move the tool off the work and bring it back to the Z0 with the Z Origin button and move the tool back to touching the top of the part to check the Z axis is really reading zero on the screen.
There have been times when doing this check showed that indeed something went wrong with the way I did the touch off.
Thanks I have reset the BB controller – i will try other suggestion thanks
