Z axis will not raise on homing
Hi,
Hoping to be able to find some help. I have had my Journeyman X-50 for about 2 weeks and it was been working great until recently. When I home the machine the Z axis does not move to the top. It considered highest point where it was last. The only way around this is to power off the machine (does not work on reset), power it back on and cancel the homing prompt and then using the gamepad to move Z all the way to the top and then do the homing sequence. Z axis works just fine during carves just wont raise at all for homing.
I’ve tried resetting the configuration and checked all of my cables.
Thanks!
https://www.dropbox.com/scl/fi/7u3hbba1ipz97o5ng9ar7/20231001_114127.mp4?rlkey=fl4im8q58ewjsfirdr883bhvi&dl=0
See the video from Onefinity on adjusting stall homing
Thank you! Will give it a try this evening.
This fixed the problem. Thanks again.
