Attaching a Pwn CNC spindle to the Masso G3
Has anyone connected a Pwn CNC spindle VFD to the G3 controller? Is it a direct connect to the spindle connection on the back of the controller?
Hey Stan,
yes, and yes.
By the way, there is a search function in this forum, which can let you find:
Yes, but only if you have the 6 pin connector.
Hi Chris, Masso has good documentation on connecting VFDs.
https://docs.masso.com.au/wiring-and-setup/setup-and-calibration/spindle-vfd-examples
The elites are prewired for pwncnc spindles… and itll work as long as you have enclosure v4 and the 6 pin control cable
