I shut down my controller last night successfully.  I came out this morning, hit the power button, it turns green, the fan starts running, but it will not boot up.  I get a “No signal” on the 10" monitor and can not connect to it over the network.  I did the emergency stop a couple of times to shut it back down so I could try to restart, but each time I try to power up the same thing as I mentioned above.
I am on the X-50.
Please help…I am dead in the water.
Thanks,
Rich
              I followed the steps and ended up reflashing the sd card.  I had unplugged the controller with the main power cable as well as the usb from the touch screen b/c I know it provides some power as well to the controller.  I reinstalled the sd card, plugged in the main plug, forgot to plug in the USB to the touch screen.  It booted up perfectly until I realized I could not do anything with it…so I plugged in the USB cable and boom, down it went.  I tried to boot the machine with the USB cable to the touch screen plugged in and no luck.  I then unplugged the USB cable to the touch screen, connected a USB external mouse I had and it came up with no problems.
It seems that the issue is with the cable or the monitor is sending something strange over that cable.
This is just a USB to USB-C cable correct?  I will replace that first and see if that helps, otherwise, seems like it might be the monitor.
Rich
