Elite Foreman with Masso G3 Machine Not Working!
I am having issues on the Y axis. I continue to get faults when trying to home. It also sounds as if the left side is a bit noisy. The gantry is racking because the Y and B side no not appear to be moving at the same speed.
I have checked square, coplanarity and DIP switches on the Y and B motors.
I have attached two videos, one of the operation and one of the masso screen as the homing is underway. I also attached photos that show that the Y side and the B side did not stop at the same point when the homing errored out.
Do I have a bad motor on the Y side?
Thanks is anvance for any thoughts!
The first step would be to update your Masso firmware to the latest 5.13 version.
Then reset the configuration files.
Do the 3 steps of this FAQ, it will most likely fix you up! Elite Series Masso Default Machine Settings
If you are still having the issue after successfully doing the 3 steps of the above faq, email into the support team at support@onefinitycnc.com and they’ll help fix you up (the 3 steps of the faq is the first thing they’d ask you to do, if you haven’t already).
Left side Y axis Carriage block - is it rubbing your table - there is some haze in the video but not enough to tell for sure…
I can’t tell if it is a shadow or what
I have completed the 3 steps in the FAQ and I still have the issue. I will contact Onefinity Support for further help.
Thanks for your response.
There is no rubbing on the table. Thanks!
I spoke with Masso reguarding this issue. They explained that a chip on the controller board was damaged due to ESD from dust collection not being earth grounded. They said a chip needed to be removed from the board and that once removed all issues would go away. They were correct. CNC is now functioning properly. Below is the email correspondance I had with Masso. Hope this helps others. Now to figure out how to ground my dust collection!
Hi Mike,
The following is my best guess based on the information provided.
From your description I suspect that you may have damage to the controller caused by a static discharge with a dust collection system being the most likely cause.
Do yuo have dust collection on yuor machine?Is the Dust collection system you have fully Earthed including the Hose?
Is your machine frame Earthed?
We have previously discussed this problem with Onefinity advising them of our findings and the cause of the problem so that they can advise their clients of the danger of adding un-Earthed dust collection systems and hoses to the machine.
I have seen this particular issue before with several controllers. All of them have the same symptoms, damage and cause.
The fault shows itself as having one or more of the following symptoms.
  • The X or Y axis immediately moves by itself on power up.
  • The X axis moves by itself when the Y axis is jogged
  • The Y axis moves by itself when the X axis is jogged.
  • The X axis moves unexpectedly and may give a motor alarm
  • The Y axis moves unexpectedly and may give a motor alarm
  • The Y & B axis move at different speeds when moving together.
  • Weird behaviour when homing the machine. Homing is not the problem but is caused by one or more of the above problems
After investigation we have established that the cause is a high voltage discharge to the Onefinity machine frame that has travelled back to the controller and damaged the component marked below. As a result this damage is not covered by MASSO warranty however it is relatively easy to fix.
:warning: CAUTION:
When working on the MASSO board make sure you earth yourself to discharges any static build up before removing the 4 screws holding the label card on the top of your MASSO.
Static electricity kills electronic components.
When you remove the cover from the MASSO controller inside the cabinet you well see the board as shown below and the IC that I have marked with an X is the component that is causing the problem.
Did Masso say what that component does or if the machine is operable without it?
Masso says that the component is not necessary for the controller to function properly.
Per Masso…
"The fix is to remove the faulty IC and leave it out. Do not replace the IC as you don’t need it.
The IC is a secondary motor driver output which you are not using and it is not connected.
