Homing Y-axis delta
I know the topic of homing precision and repeatability has been covered in depth here, but my issue is a little different. I have read many of the threads on homing (and truly appreciate the depth of these discussions).
When I home the machine (after a boot up), the Y axes don’t seem to home to the same offset after the stall. I assume this is because one side of the machine is stalling before the other, but I am not sure why or if there is anything I can do about it.
I have measured the gap between the front rail mounts and the bearing (with feeler gauges) and the delta can be 1/2 mm or slightly more after some homing processes.
I am wondering if this is contributing to some of my out-of-square issues, but generally want to know how precise and repeatable these operations are.
This is on a WW Pro, and I know the Elite uses an entirely different mechanism.
Thanks in advance,
JohnL
Hey John,
Thanks for sending this Aiph5u!
I have read a number of your posts on homing (e.g. Homing != Zero), and have a much better understanding of the issues, precision and inconsistencies involved with homing. Thanks for all of your posts, particularly the gcode snippets for saving/restoring posteition information.
Just yesterday I decided to do a partial tear down of my 1F WW and “reset” all of the rails. I set up a test bed (with a wide, square piece of Baltic Birch) and jogged the machine to each of the corners with a 30d v-bit to mark the corners.
Everything seemed to be spot on after the adjustment. The diagonals measured 1154mm each, as they should.
I am going to do some more testing, but I think I now have a setup where I can set up a fence to calibrate and adjust as needed.
Thanks again,
JohnL
