I just finished assembling my new (first) CNC.
The Makita Router (in the lowest setting on the Z slider) is not reaching the 3/4" Spoil board when fully lowered and the flattening bit inserted to the mark (Amana 45525).
I assume it may be due to the riser… Any thoughts?
I think you’ve likely mounted your z slider too high. Check these bolts, in the photo I’ve mounted as high as possible, but am using a spindle. Your router is shorter. See if you have room to mount it lower.
