Surfacing question
Hi,
Newbie here.
How can I get my makita to plunge lower so I can surface my spoil board. I have my makita on the lowest setting on the mount and it bottoms out on the z before i can reach the spoil board. Im using a 1/4 - 3 wing bit thats 1.5" long. Does one have to double up the height of spoilboard? photos for reference.
Any suggestions?
You might be able to reach the surface of your spoilboard with a 3/4 or 1 inch mortising bit like this.
My bit is 1.5" long already.
I’m in the same exact boat. Just got mine setup today and facing the same issue. I thought it maybe the 80mm mount that I have with a shimmed Makita router (my spindle arrives mid March) but I see you have the 65mm mount. I see that on QCW table the machine sits lower than the table and then the spoilboard added on top. I’m thinking on shop built tables like yours and mine maybe a “double thick” spoilboard must be used when using a Makita router. Then again I could be wrong. I’m still investigating myself.
Hey all,
this is the way the Onefinity’s Z assembly is designed. It does not allow the milling motor mount to protrude downward beyond the end of the Z rails. See here and here for explanation.
You would likely have to remount the z-slider to allow you a little further reach. Otherwise yes you’d have to build up your spoilboard. Onefinity recommends like a couple inches of spoilboard or something in their manual.
There are router bit extensions on the market, if you were to go this route, buy the best one you can to minimize run out.
Pat
There are also longer mortising bits like this one. Smaller diameter so it will take longer. Just another possible option besides a thicker waste board.
+1 - maybe your Z slider is mounted too high up. I don’t recall having this issue when I used a Makita
Do you have a screenshot of your setup so I can compare?
I can share one, but I have the Z-20 and also use a spindle so not sure how much help it’ll be. Did you see this? Z Mounting Hole Pro/Con This may be of help. Let me know if you still want the pic
Add another piece of 3/4 mdf (raise the spoil board)
I was trying to reduce the height my t track clamps have to overcome
You’re issue is covered in the manual.
You have a Foreman and the makita router, which uses the taller x50 rails on the Y rails versus the shorter x-35 rails on the journeyman and woodworker. Therefore, you must install 2 pieces of 3/4 mdf stacked on top of each other to reach, especially with short bits like a flattening bit.
